boost at 8psi?!
NottsLCR
243
Nottingham
Heres the problem - When i start the car in the morning and drive to work the car will only boost to around 8psi.if i turn the engine off and start it again the car will boost to 22psi.The only trend I found recently was that the temperature sempt to be below zero when it would only boost to 8psi. I changed the coolant thremostat to green top as had one to fit but no difference.VAG Come gives fault - 17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
I have removed and cleaned the DV and checked all the vacuum hoses and appear ok,its really getting on my nerves and ideas?
NottsLCR
243
Nottingham
Cheers,
I spent ages checking the hoses as it seems to be a commen thing but cant see any splits or lose clips plus it works every time other than when i first start which is whats really confusing me.:think:
