Yes, you are correct. When you measure boost with VAG-COM, you should first take a look at the atmospheric pressure (around 990mbar). If VAG-COM shows 1700mbar, then the actual turbo pressure is around 700mbar (0.7 bar).
Normal pressure for a non-chipped 110 TDi is around 0.9 bar sustained.
