Boost gauge, a couple of pointers needed
danny20vt
going back to basics
i'm thinking of getting a boost gauge and have looked at guides for fitting on here, i'm a bit more confident but the wiring seems to confuse me a bit ( not very difficult:confused: )
Pabs guide shows 2 wires connected to the light switch others show 3, are 3 wires for the fancy dancy led gauges and 2 wires for normal light up gauges? also i'm about to put a DV coldside kit on, is the vacuum pipe still ok joining at the DV or is the FPR a better source?
these are the gauges i've been thinking of
http://cgi.ebay.co.uk/PROSPORT-RED-AMBER-WHITE-BOOST-GAUGE-PSI_W0QQitemZ110380256975QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item110380256975&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
http://cgi.ebay.co.uk/SMOKED-TURBO-BOOST-GAUGE-NISSAN-SKYLINE-200SX-S14-S15_W0QQitemZ180351797926QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item180351797926&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
i've not thought of where to mount it yet so any opinions would be welcome
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
use the fpr as your vac source. 3 wires is when the gauge has a memory (ie for a multi colour gauge to remember the colour to be used).
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
most go through a grommet on the drivers side of the scuttle panel.
i didnt have one so i greased it up and fed it through the bonnet release cable grommet. no leaks or problems.
Deleted member 20376
i like the look of the last guages you posted.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Not all Leons are the same I put boost guage in mine on tuesday and looked at this guide before starting
http://www.seatcupra.net/index.php?option=com_content&task=view&id=540&Itemid=6
When I actually got to fit it my normal 02 Leon Cupra doesn't have that gromit in the picture, instead it has a really big funny shaped gromit that the main harness goes through.................you put your vacum line through there :)
The wiring is the same as the guide tho, the wiring is the easy bit getting that vacum line routed is the hard part.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Get a picture up mate, as the wiring harness cover I'd have thought was a mass produced item, unless someone as already added a rubber grommet.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I can't get a picture unless I take the wipers and scuttle panel off.
I know what your saying about the main harness and I agree its prob same on all leons but that little gromit on the picture guide is 100% not there on my car :)
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I put mine through the gromit with the main harness to save drilling extra holes, I also ran it through the other main harness gromit into the engine bay so it looks neat and tidy :)
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
This is where I went through into enging bay and same harness gromit in bulkhead to get behind dash
Saved myself a lot of money by buying a universal pillar mount and spending hour or so making it fit
Looks better at night when its all lit up :)
tripdiesel
Leon Cupra R 225
Mar 21, 2009
162
Isle of Wight
I went in through the bulhead on a unused grommit by the bonnet release cable and t-pieced of the hose that goes into the inlet manifold, i was not sure about using the FPR as i wanted to leave anything with fueling alone.
The wiring i connected the wires into the dimmer control and lighting control, using the dimmer wire for control and used the main 12v off the main lighting control, but that was for a fancy led multi colour.
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
Adam cupra 16v have you took wipers and scuttle panel off to drill in that grommet ? Im not sure how to do that. Is there a seal between that panel and windscreen ?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Yeah but don't drill it because its soft rubber you can either cut it with a knife of push a screwdriver of something simular through to make the hole, same for the gromit behind in the bulkhead.
Wipers are 2 13mm nuts, scuttle trim lifts off.
w8scc
Kasper the K1
Apr 16, 2009
173
Leicester
Adam.. how did you fit this to the pillar.?? was it easy? I am going to buy one but dont wana drill to many holes :)
Cheers mate.
w8scc
Kasper the K1
Apr 16, 2009
173
Leicester
Was yours just totally universal..? becuase iv seen one on ebay for around 30quid.. single pod for direct fit to Cupra Ra pillar aparently..
Scott.
