boost gauge needle flickering
Jun 29, 2001
537
Surrey
I thought these Ultralites were supposed to be good quality :no:
Phil, any of your mates over in wales got a gauge you can test? Would only take 10 mins to do and could rule out your gauge being at fault or not.
freddie
super duper cupra...
Apr 2, 2007
350
Hull, East Yorkshire
I've had the same problem! when i first installed my boost gauge i 't'd from inlet manifold and it operated fine, then uprated all vac hoses with silicon ones and now its started flickering, i think its because the silicon hoses gets warm and supple then pulses under boost conditions because on vacum it doesn't.
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
Thats well nice i like that!!
Im guessing theres not much chance it would be the same size as one i have now in the door pillar though.. If its a bit bigger it wouldnt be a problem though!
So presuming i have the standard boost gauge plumbed in and wanted to swap for that how much extra work would it be ? I presume id need to now get power to it as well ?
Sorry lol im not familiar with guages :p
Nov 2, 2004
9,335
South Wales
Its deffo the gauge as i've said. Its the second gauge i've had plumbed in the same place using the same connection.
It was fine when i had it.
carlisle pete
649
yer mate its the same size as normal!! erm yer u need to wire it in! il find out exactly what as it came with like a little control unit with it aswell!!
Bogwoppit
1,085
Lincs
I use a Autometer Phantom boost gauge which is T'd into the top of the DV, I get no flicker at all and my boost gauge sits on 0 when the engine is off. I used the t piece and the hard vacuum tubing that came with the gauge.
