I'm getting crazy of this ****! Jacked up the car and tighten the hose clamp, took power of ecu, did a tba og then drove around with some full rpm runs... Boost Is still where it used to be.
I'm pretty confident that its sealed now, the hoseclamp did look a bit fragile, so I replaced it...
4.th gear run:
Code:
	Group A:	'020				Group B:	'115				Group C:	'003
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres,	Absolute Pres,		RPM	Mass Flow	Load	Ign, Timing
	TIME					TIME					TIME
Marker	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	 g/s	%	 °BTDC
2	433,32	0	0	0	2,3	432	2200	31,6	1010	1030	432,71	2240	12,97	9,8	33,8
	435,33	0	0,8	3	2,3	434,02	2400	96,2	1850	1240	434,68	2560	69,69	100	14,3
	437,36	0	0	2,3	1,5	436,04	2960	129,3	1800	1530	436,71	3160	77	100	17,3
	439	0	0	1,5	0,8	437,89	3480	127,1	1820	1530	438,44	3640	89,28	100	19,5
	440,79	0	0	0,8	0	439,52	3960	130,1	1820	1550	440,16	4120	100,25	100	20,3
	442,75	0	0	0	0	441,46	4400	124,8	1790	1540	442,07	4560	107,31	100	20,3
	444,75	0	0	0	0	443,38	4880	124,8	1750	1520	444,07	5040	120,28	100	20,3
	446,68	0	0	0	0	445,4	5320	132,3	1800	1550	446,08	5480	137,72	100	18,8
	448,38	0	0	0	0	447,22	5720	140,6	1850	1650	447,82	5840	154,86	100	17,3
	450,18	0	0	3	0	448,96	6080	130,8	1840	1670	449,54	6160	153,92	100	19,5
One guy I know had a boost leak at his MAP sensor for a long time before he found it.
Watch that the hose clamps aren't too tight and perhaps might have split the hoses.
I take it you've been all over the boost system with your soapy solution?
I havent be over them all yet, cause I did not have any compressor, so tomorrow I will do it all over again to check for new faults, however, it seems like it knock alot less now!...
