martziniuk
Octy driver
Oct 17, 2007
53
Driffield, good old yorkshire
Hi all,
I fitted an FMIC recently to my Octavia Vrs with the AUQ engine (same as the cupra). I had this before fitting but the actual does not meet up to the requested boost. The N75 is in no way maxed out as the graphs show, so why doesn't the N75 compensate for the difference? Any advice appreciated.
Boost
N75 duty cycle, sorry i started @3000rpm
I don't think the duty cycle is too bad, just maybe the graph makes it look bad.
Here are the figures i used for it
Thanks for your help, I think i will buy a boost leak tester and go from there.
Your car is running a little lean - possibly a maf past its sell-by date? Actual meets requested fine all the way to over 5k rpm and then starts to fall away a bit. Whilst the turbo does run out of puff, you should be able to achieve a bit more high rpm boost than it actually does. I note you have an N75J - was it mapped for that? Try putting your original N75 on and see what it does?
Yeah i agree about it dropping off at the top end. My sig is a bit old, i had to take the J valve off after it went into limp and kept doing it after the scn RR day@ RS Tuning back in may last yr. So these logs are from the F valve. AFAIK the MAF is the original after 115k so this may be the problem.
Another question would the FMIC make it run a little leaner?
Thanks for the reply ;)
No, it won't.
It might be worth trying to borrow an N75 to try - to see if it performs differently to yours.
Thanks again for the reply.
I have got and tried a new one but interestingly it gave slightly worse results, the high mileage one gave the best results.
It just seems strange that the N75 will barely adjust to compensate the lack of boost. I did previous logs before the FMIC and they were better but still not right. I also went back to standard airbox and performance panel filter and did logs tonight but no difference :think:
Can you tell me how you know it's running lean too please?
Just done an AFR run on block 031, looks to be quite good to me. Interestingly where the boost drops off in the rev range AFR suddenly gets a lot richer, as in 11:1. Could the mixture being too rich have an effect on the boost dropping off????. Comments please.......
