kevsn
57
Earth
afternoon all
just been to get my car on vag com because ive noticed that sometimes my turbo just doesnt seem to be working.
got the following code
17705: pressure drop between turbo and throttle valve. p1297. intermitent.
does anyone know what the problem could be with coz the garage doesnt seem to know (or doesnt want to tell me as its under waranty with them).
sorry my car it a 2001 leon cupra totally standard (180 bhp)
Thanks Kev
boost leak mate, could be a pipe popped off, the dumpvalve could be goosed, or an hole in a pipe somewhere, simply needs a pressure/smoke test to find it
hth
hi
if it was a boost leak would it not be there all the time and not be intermitent
i dont know im new to this
is there a way to tell if the dumpvalve is goosed
not always, assometime you need max boost to blow the hole lol, my bet the dv, if its stadard its prob failed, most do,
people upgrade to a forge 007p there about £70 from us
yeah the dv is standard and my guess is its the original so its 9 years old.
do you think its worth replacing that?
hope its as simple as that and not a hole in a pipe coz i havnt a clue where to start looking
I would love to do a smoke test on my system but I'm not sure if i can do that on my own. I need to find a garage that does this.
I had this error recently, got a forge service kit for my DV007p, problem solved.Also if a boost pipe was off you would now straight away.For smaller leaks under high boost, these are a pain to diagnose/fix, pressure test should do it though.
BTW i wonder does the leak test for the forge DV work on the OEM DV, same concept i would have thought.
how would i test my dv then?
this is the way you can test a Forge DV, not sure if it works on the OEM DV, but worth a shot.
Use a pen and push the piston of the valve upwards against the
spring to ensure that it moves without restriction.
Then with the piston pushed fully up, ie with the spring
compressed, place your finger over the top nipple to form a
seal.
Now remove the pen, keeping your finger in place. The
piston should remain in place until you remove your finger
from the nipple, at which point the piston will travel back.
hi i got a cuper r 225 i had it remap and is got forge dump valve and k.n ar filtter put it on roll road b4 gor work dun it wos put awt 183bhp so add all off then naw is put 233bhp got told is not hold boost well ne one no y is so low on bhp and boost
Is this a new version of english, i lost what you were tyring to say halfway through your post.!
i got a cuper r 225 and is b remap two 255bhp but is on runing 233bhp got told is boost prob can u hellp me
How do you know its only running 233bhp? Did you log the ECU, there could be a number of reasons for being down 20bhp.
The DV connection from the TIP to the charge turbo charge pipe, if you have a remap it is also recommended to up grade this component.
P.S start a new thread and i am sure you will get some more help.
i got it rooling road b4 remap wos 183bhp got remap naw run 233bhp sosumthink is rong it a 225bhp
i think my mk1 might have a boost leak, when my foot is pressed gentley against the accelerator before boost i get a slight loss of power and then the power comes back. is this a symptom as well?
