the striker plate most probably needs adjusting.. if the 'lock mechanisn' is not loose..try the part it locks on/into (bit on the main body of the car.. mine was always doing this when I first got the smashed boot opened....
big Tor-X driver or a flat bladed screw driver will tighten it
ihi ibiza for a daily driver? do you **** gold nuggets?
more details?
I remember seeing a yellow one on piston heads with low mileage but white alloys, plus that black one with the strange bodykit on
same prob on my mk2 , just release the screws/allen bolts on the pin as brummy said , it will move , pull it slightly toward you and tighten up . job done .
the pictures dont do the car justice , the arch extensions look quite good on the car , the front bumper looks good as well , looks like a rs4 bumper , lines up like the oe bumper as well , might just end up ripping it all of though , and put it totally back to standard body work wise
