Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
if you stick an SPS into a non revo'd car - it'll beep away merrily not doing anything
...beep more than it would when used on a Revoed car?
how did the beeping compare to using in yours?
When I use it on mine, it beeps slowly - maybe a second and a half between each beep. On yours, it was beeping 'merrily' as m0rk described. This alone leads me to think your car has not got Revo. If it's had a trial, it has gone and isn't the cause of the problem.
I feel we should be looking for other chipping / mapping culprits.
indeed, ill try and get in touch with previous owner, revo was only mentioned as thats what my tuning mate thought as he came across one before, im sure we'll get to the end of this![]()
Looks like a boost leak to me. Block 32 is high and climbing.
Is the 5000rpm limit the same on every run, so it's an accurate limiter? Could be apr's in valet mode.
Maf still looks ok 0.35 bar. Lcr should be running 12psi, not 5 though.
What about a mashed Cat.
We logged a guy's that came to a meet one day.
We swapped ECU, MAF, N75 and DV it didnt rev easy and didn't boost over 6psi too.
He took it to a specialist and they unbolted the downpipe to reveal a very mashed cat.
Looked like this.
Might be worth logging lambda sensor readings as it sounds very similar.
Didn't it smell? I had a car where the cat collapsed and it would hardly rev at all (and stank) , but the LCR does have two cats............
SPS 3 will bleep when it's powered up... regardless of whether the car has Revo on or not. As such it can't be relied upon to verify whether software is on the car or not. We haven't locked out any read function on the ECU so anyone with the right tools should be able to dump code out of it... whether they can make sense of the encryption is another thing though.
Yep, your local Revo dealer can check whether there's Revo code on there or not!
...just seems a bit odd that this all happend after someone tried to read it, Ive no idea what he was using but he tried 2 diff progs and it couldnt read the ECU code, i only asked him to do it as I was unconvinced the car had actually been chipped, maybe it was this underlying problem![]()
It certainly would make me suspicious...
Looked like this.
Can this logging be done on freeware version of vagcom and if so how? I maybe able to test myself, i guess this is looking like big bucks if thats the case![]()
