December
239
Cluj-Napoca, North Romania
Hello... i need to change my brake fluid asap... i think it's nearly empty...
I bought some DOT4 Castrol Brake Fluid from the supermarket today and i need advice on how to change it.
What should i watch out for ? Do i need to empty the old fluid and put in the new one; or simply add the new one over the old etc... ?
Help me Please asap >_<
DO NOT EMPTY OLD FLUID OUT.
pressure bleed or vacuum bleed only.
If in doubt get it done professioanlly by the above methods only.
if i do.. im going to get sooo ripped off >_<;
possibly if you dont know any good trustworthy garages
alternatively you risk getting air into your brake system, which on leon/golf's is notorious, resulting in soft, longer pedal, and in some circumstances without pressure bleed or vacuum bleed (blow it out, suck it out) the pedal up-down method risks rolling the master cylinder seals resulting in very poor to no brakes at all (been there, done that on a mk4 golf and it is not fun at all replacing a master cylinder)
DIY (do it yourself) pressure bleed kits here run off the cars tyre, pressurising the resevoir.
Gunsens is a make.. maybe they do a similar kit where you are?
Urm... Might be a struggle in North Romania. I can't think of any off the top of my head...:(
If your brakes feel fine and the fluid in the reservoir is the same, just top it up.
If the brakes are spongy, then you need to find a garage.
sorry andy.. Correction... its not nearly empty its just a little below the "MIN" indicator. I thought it was nearly empty because of the "spongy" feel i got today when braking...
I immediately thought there must be something wrong with the fluid... but there's no reason for the brakes to start behaving erratically all of a sudden.
Now i'm worried there might be something else wrong with the brakes... and i'll take the car in to a garage as soon as i can.
I'll take in the fluid i bought today and have them put it in.
It's strange... the brakes felt like they were going in too deep... normally after i pinch the brakes ~1/2cm the car stars braking slowly. But today i felt like my foot was going in about 4cm before i felt the car slowing down and after pushing a little bit more it would brake too much... There was no intermediate stage.
I hope its not the ABS or anything; that would be very costly >_<;... The ABS checks out ok on my dashboard when i start the engine but there might aswell be something wrong with it regardless.
if the fluid level has dropped, this could be your low pads (front & rear)
if fluid is old, and pads are thin/worn out, then they will overheat much faster... old fluid can have abosrbed moisture, which lowers its boiling boint massively. this when hot can give you a "long" pedal.
get it checked m8.
its your brakes after all
