Brake light on dash not showing
sav-fr
95
Cannock, jun 10a m6
Hi all,
I have a question, when you turn the ignition on the lights on the Dash light up for about 3 sec then some go out, correct?
My Problem is that my brake sense light doesn’t light up; does this mean the bulb has gone or the brake pad sense is not working?
I have never noticed this before so don’t know if it's nerve work or only just gone off.
Thanks for your help
Sav
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
the brake pad sensor wont come on unless your pads are low enough to set it off. wouldnt worry, keep a visual check of your pads, the sensors are notoriously bad anyway
sav-fr
95
Cannock, jun 10a m6
Yer I know that but I was under the impression that when you turn the car on, the light would illuminate, for about 3 sec then go out if all was well, mine is not coming on at all.
Sav
