Brake lights
SRGTD
2,745
1,605
If the car’s using the brakes to slow down when ACC is being used, the brake lights should illuminate.
Reactions: Richiepoos
tomek_olo
Cupra Leon ST VZ 2.0 245 DNPA DQ381
Jan 28, 2022
146
52
Actually that is visible in the instrument cluster - the brake lights on the thumbnail of the car come on. Neat!
  • Wow
BoomerBoom
783
289
If the cruise is set then you should also see the brake pedal move, or feel it with your foot, so the brake lights come on the same as if you pushed it.
The only weird thing is the regen with the DSG, the car can start slowing quite hard but the brake lights stay off, presumably as it's no different to changing down in a manual. It's caught out a few people following me up to junctions, as the car starts to regen really early compared to their braking point.
josh2023
50
Ireland
I've never noticed a brake light illumination on the cockpit display when cruise control is enabled .I will check the brake pedal feel next time.
Yern
698
352
Same if you engage the speed limiter and exceed the set speed (e.g. going downhill).
