Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Hello you all,
I've decided to upgrade my front brakes on my 16v due to a possible trackday. As it is I'll probably be after getting the Padgid FR front pads, Brembo Max front discs and some 5.1 fluid.
Problem is that I've been on the GSF website (and yes, I did a search on here first), but I'm not too sure which ones are the correct parts. I know I need the 280mm 4 stud discs, but they don't say which is which. They just say VR6 or similar which could potentially be the 5 stud version.
I'm sure some of you have ordered up this combination before, so could you please please look up the part numbers of those parts.
Many thanks in advance :clap:
Mig
No 4 stud 280 Brembo Max discs, you just need Corrado G60 4 stud fitment
Yeah, I've just checked it and you are right. That means no ATE powerdiscs or Brembo Max discs in the 280mm 4 stud fitment :cry:
Can anyone recommend any other grooved or drilled discs??
Many thanks
Mig
im putting Ibiza 20vt Discs and pads on mine. they are 280mm
all you need is the callipers/carriers i believe maybe also the hoses but im not 100% sure. when i put mine on im goin to take pics so people can use them for referance if they want to do the same.
Mk2 2.0 16v brakes are identical to the Mk3 1.8 20vT brakes ;)
G60 Corrado fitment if you're getting the parts from GSF/ECP.
Speak to Bill (ibizacupra) about grooved/patterned discs.... I'm pretty sure he was looking at getting some custom made ;)
