Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
I think this would be good as a sticky for others so they dont need to keep posting light sizes.
If i miss any do tell :)
Exterior:
Front:
Dipped Headlights : H7
Full Headlights : H1
Indicators : 382
Sidelights : 501 Wedges
Fogs : H3
Rear:
Indicators : 382
Reverse : 382
Stop/tail: 380 Dual filliment.
Fogs : 382
Numberplate : Festoon 39mm.
Interior
Glove Box : Festoon 36/39mm
Boot : Festoon 39mm
Central Light: 2x 501 wedges and Festoon 42mm
Door Lights: Festoon: 36/39mm
Roof Linning Lights: T5
Some may disagree with sizes on bulbs by a mm or two but the sizes are based on this fabulous seller bellow
LEDs Festoons etc
http://stores.ebay.com/warden-jp2002
HIDs
http://stores.ebay.co.uk/diane-shop
p.s order in dollars and take advantage that our economy is stronger.
The boot light on my LCR in no way would accept a 36mm festoon, I know as I ordered one by accident :( 39/40mm will however.
i agree make it a sticky :) took me ages the other day to find out what the part number was for a replacement brake light bulb.. probably me being a n00b but still handy to have as a sticky!:)
1-2mm off will not be a problem.
Its a matter of just pushing harder or opening the terminals.
The Glovebox is the only case where you can´t place a larger Festoon.
I got the rear roof light bulbs out today but they dont have anything on them to say what they are? Has anyone changed these for LED's? It would be a real shame if thes bulbs cant be changed. They seem to be wired in to a plastic holder which clips in to the light housing.
I fitted my rear roof light bulbs today but was expecting them to be a bit brighter? Its a bit of a shame coz i think the interior front LEDs look really good :clap:
Question for UncleFester;
How did you get the rear light cluster to come off? I've just been out there to have a look at bulb sizes and I got nowhere. Is it just a case of getting a srewdriver behind the unit and using some gentle persuassion? (Not sure if I've just killed the central locking by pocking and prodding. It worked fine when I opened the car, but not when I came to lock up.)
Any clues you can give me would be appreciated.
Mark
I have done near enough a full interior conversion bar the roof lining lights. Anyone know what size they are? What type of led etc...???
anyone have any problems when replacing the two 5w5 bulbs in the light above the rear view mirror with led ones. the festoon bulb in the middle works but the two 5w5 bulbs glow dimmly and flicker.
