Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Without sounding like I'm stating the obvious, what you should probably do is take it to the dealer or specialist. When I took mine in they wouldn't let me take the car away until the tech had looked properly as if the chain slips too far or comes off you're looking at a big bill.
no but it will get rid of the crapy oil that may be blocking the pick up witch could of made the tensioner fail i changed my oil every month when mine was playing up untill i got it sorted (witch was six months) just to keep the pick up clean and did the filter every two months if the tensioners gon or going you will have a tapping on first start up as it relies on oil pressure to keep the chain tight and when its gone/going it cant keep the pressure so the chain rattsels about untill the pressure is there i found if i reved the car the noise went away but later came back on idle after a while
Ok so I changed the camshaft sensor and cleaned the codes,took it out for a drive and under load suffered a slight what felt like misfire.when I got back I scanned the car again and I had the same fault as before.the engine also seems to have a slight misfire or knock on idle every 5 seconds or so.I will be trying changing the crankshaft sensor in the next few days in the hope that it's the cause.
Abit of an update,so after changing the camshaft and crankshaft position sensors I still had the same fault coming up.so today the cambelt was checked and was found to be very slightly out.I roller bearing was also found to be sticking slightly too,so hopefully this was the cause of my faults.
1 week later and no fault codes,seems the problem was a £25 cambelt roller bearing.a funny thing tho.when the light was on the car was so much faster,very strange.
