I havent done the bypass, didnt like the idea of having a pipe with no stop end or one way valve (apparently you cant because it effects performance) ~ dust and sh*t will probably get in and every guide seems to be for every engine except a BAM engine (which i have).
To be fair skahigh, the guides are not definitive... and there isnt a agreed general "consensus" as to whether the pipes should be blocked off, nor does it show or expand upon other pipe removals on the 249, as im sure not everyone wants dirt and dust going into their pipe work/engine.
why would you want to have the esp button turned off permanately?...its a safety device first and foremost
This is the simplest it can be as far as I'm concerned....
You disconnect the pipes where the two blue dots are, then run one piece of vac hose between the two nipples (underside of the inlet manifold to the top of the dump valve), thats it. People have made this mod so much more complicated by t'ing in to various places.
i have done the N249 bypass. i must admit, this mod is fantastic, the car performs much better. dump valve seems to be more under control. car seems to pull better aswell.
the best thing about this mod, its free woop woop.
i would like to no how to remove the N249 valve completely, without any lights goin on ect.
