Denzil
92
10
South Wales
Hi guys
I've got archoil fuel additive that i want to use, but when i try to put the nozzle into the fuel tank, the black plastic flap will not open.
I've even tried a funnel with a different sized nozzle, but still no joy. However i never have a problem with the flap when filling up with fuel.
Any ideas on what is preventing it from opening?
Den
Found this on pistonheads, might help
Hi guys
It looks like I'll need a tube or funnel that has a 25mm diameter which is the same as a UK diesel nozzle.
Can I just ask why the additive? Unless your car is spitting plumes and is generally very unhealthy, I’ve always taken fuel additives as a last resort?
If your feeling slightly bogged down. Maybe an Italian tune up is in order?
If you are sure you will not try to fill her with unleaded - take out the miss fueling device.
Takes about a minute - simple enough to refit if you really want it back in.
Instead of using an additive use premium fuel like V-power it has all the additives and cleaning agents you'll ever need.
Reactions: LouG and Legojon
