can't open my boot
h6kav
My boot has jammed shut has anyone got any ideas how to open it its a
(2000)leon cupra 1.8t have tried opening it with the key and no luck?
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
try lifting the havdle and giving a firm whack with the palm of your hand just to the side of thee handle. somtimes works.
i have had/got the same trouble with my mk4 ibiza, seems water from the rear wiper drips on on the locking module and mechanism.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
then usin a wd-40 with a straw, spray some boot key hole, let it rweact and trya gin via, remote or manual key.
Pabs
5,936
Basingstoke
good luck - if you have no joy you'll have to open it from the inside. Which is a pain. You need to remove boot trim etc.
Very common problem - i actually got my bootlock replaced by the garage TWICE! (And looked at a further 3 times)
h6kav
ive got to get it sorted asap as iam off on holiday on the 29th therefore need to get suitcases in the car. Pabs love your leon?
Pabs
5,936
Basingstoke
thanks mate :) - if its still in warranty see if the dealer can do anything for you - if not you'll have to try the "thump" method above (worked for me a couple of times) but otherwise it'll be a real pain to sort :(
It's definately down to the bad weather - water/ice/fog etc - messed up my boot lock 2 years running.
h6kav
since the bad weather past 3 days my boot won't open, mirrors won't fold and condensation in the car
h6kav
thats it ive tried everythink i can think of to open this boot and its not happening does anyone have any idea how much it will cost to sort the lock out at the main dealer?
Pabs
5,936
Basingstoke
check your fuses again mate... if you say your mirrors don't fold chances are you've got a dead fuse. Manual will show you which fuses are for which circuits.
I have no idea as to cost to get repaired at dealer, but the last two times i've needed this changing, it has taken a long time. The boot lock needs to come from SPAIN, and is specific for your car - the lock needs to be coded to your chassis number i think.....
neill70
i have a similair problem with mine, it would not lock the boot with the remote or key so i took the trim off and moved the locking bar which worked for a few days but noticed today it was not locking again so ive taken the lock out and thats ok looks li the motor on the boot door has packed up so now i have to climb in the boot and open it from inside.
h6kav
neill70 will get a price from the dealer and let you know next week
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
have you taken the boot trim out yet?
that's the only way I can think of... it'll be invasive though, with a knife
Smart22186
Newbie
Feb 21, 2006
353
Peterborough, England
can anyone explain how to remove the boot trim cover (or atleast where to start) boot will opne , but hose has come off rear washer and i need to replace, have removed 2 hidden screws in handle (on inside) BUT JUST CANT LEAVER OFF! HELP ME
Pabs
5,936
Basingstoke
Smart22186 - you'll need to remove 2 screws from each grab handle, and then, IIRC, its just a case of a short/sharp tug (oohhh er missus) of the trim, as its held on with those damn clips that you'll spend the next 20mins trying to find...... lol
I don't THINK there are any more screws.....
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
if boot wont open then it will be tricky as im sure some of the clips are where you cant get to, so as mork said maybe a knife job!!
But dont quote me!!
The MoffMeister
Apr 4, 2006
2,937
colchester
just looked at mine when you try to get it off youll have to probably break the plastic as its a one piece that the lock goes through unless you can do it without needing to snap the plastic!
