virdi
892
Middlesex
Hi all,
I recently had a chance to run my car (LCR - IHI Converted) on a Private Test Track ;)
....at about 120+ the steering seems to get very shakey etc....
What should I look at?
...also - powering out of corners - I can never get the power down, I seem to get this funny vibration/rumble if I power out of the corner..? is this the inside wheel not getting grip? or the ESP? or the Diff?
The vibration could always be wheel hop. I get this when pulling away in mine, it has too much torque. I am in the process of getting an uprated dog-bone mount to see if this helps things. Have you upgraded any of your mounting?
Rumble? like ABS?
I suspect ESP is kicking in, is the yellow light on the dash flickering?
Two options to help;-
- lowered uprated suspension and anti-roll bars
- Quaife or Peloquin type ATB Diff
either option will cost £1000 to £1500 if done right incl fitting
It might sound like a very basic answer but i had the problem once getting 110 in my previous car, turned out the wheel balance on just 1 wheel was just slightly out after having a tyre change 3 months prior, but never went fast enough to know untill that day!
another thing to check is the plastic trim under the bumper, it plays a big part in stability at high speed.
With ARBs - The thicker they are... the more stiffer they are?
Hence - The more the body roll is reduced?
is that how it works?
and get all 4 wheel's balanced and ask them if any were out by 5/10g? i would guess
