divmcm30
Hi all lookin for some help on ma seat ibiza cupra r first I will give spec of engine k03s turbo withe new acuator stage 2 revo remap running 1.3 bar level 6 aggression forged con rods forge front mount intercooler all silicon boost hoses with steel boost lines 3inch costom exhaust from turbo back heat wrapped front to back s3 330cc injectors g60 flywheel induction kit short shifter.... Problem am having with the car is engine management light started flashing car started sounding ruff no power so a changed spark plugs and coil pack still the same???? Now am thinkin its a injector how can a tell if a injector is no doin its job??? Can a just take the old injetors out and put 440 injetors init or will a need 2 remap it
Av not plugged it in yet will get it plugged on a computer 2moro av checked the coils one bye one taken the coils out put a spark plug in them one bye one and thay are all sparking will update when its been on computer
the coil can be still be faulty even though its giving a spark when you put a put a plug in. the coils break down over time and become intermittent. this happened to mine and sounds like the same symptoms, the car stuttered under load and the eml was flashing
+1, this is most true! It's more a spark being blown out as its not strong enough rather than the coil not sparking at all...
Sent from my iPad Mini using Tapatalk HD
