car scanned coolant pump open circuit
Marshall
3,256
Bonnie Scotland
The reason it came on at cold start was the car was hot when parked up and the ignition hadn't been turned on again so that was the first chance to show the error.
Petecog79
296
Pump arrived today will fit this week . Just noticed the flat spots I had in third n fourth at 4k have gone since eml on!
Petecog79
296
Pump fitted. If it for some reason isn't the pump how soon will if be before eml.comes on. Ive used car twice now 3 hours apart and didnt hold back on throttle, so far light is still off. When I removed pump there is something rattling inside, gonna strip it and have look.
Marshall
3,256
Bonnie Scotland
The impeller was seized on mine!
You'd know within a day or so. When the cars warm and you switch off you can feel if the pumps running.
It'll be sorted now and at a cheaper price
Petecog79
296
Cant feel it running but no light so far. Stripped pump not much inside to go wrongbonly one moving part thr mahnetised impeller, electronic control sealed but looks brand new!
Petecog79
296
Mate no way impeller can seize it sits on magnetic coil totally sealed unit ie. One moving part! Which cant fail unless rusted
Petecog79
296
Thinkin of golf gti year 2010 or golf r or c class c250 cdi in march no idea what to get
steve7786
78
8
How have you gon't on with this and how easy is it to swap as i might have the same problem. I had a coolant fault that i cleared and came back after a long run and on starting the engine i will make sure it's the right code before i commit to buying nay parts though.
Petecog79
296
Car is sorted mate had first fault code as coolant pump open circuit I cleared it and it came straight back on. Checked the code again but only had a universal scanner which gave code 9754 which is exactly same fault. I ordered pump after looking at code on faulty pump. V easy to fit just take undertray off and its right in front of sump. Clamped coolant pipes and removed pump then fit the new one. Two pipes and a connector. My pump came with new bracket attatched which I removed as its easier using existing one. Only one minor prob is I used pliers to remove 3 torx screws that hold pump to bracket as no room to get one if them out.
steve7786
78
8
Thanks for the info, i have a VCDS cable but will check as i think i have the same issue. Car is a 10 plate so i am hoping it's not the start of things to come
Petecog79
296
Like ive said before seats most unreliable cars ive owned! Still like em tho but wont buy another.
