Parsy-Cupra
Right sorry everyone, I know people are gonna say do a "search" but i've searched and dont really know where to start. Any help or a point in the right direction would be much appreciated.
I noticed the other day while accelerating my car boosts to 20psi then quickly (bout 3500rpm) drops to 15 and then holds bout 10psi. It seems to be like holding back, hard to explain so got it on my vag-com and this is what showed up,
Address 01: Engine
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 79413
9 Faults Found:
17535 - Long Term Fuel Trim mult., Bank1 System too Rich - Intermittent
18010 - Power Supply (B+) Terminal 30 Low Voltage- Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected - Intermittent
16685 - Cyl.1 Misfire Detected - Intermittent
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-10 - - - Intermittent
16687 - Cyl.3 Misfire Detected - Intermittent
16688 - Cyl.4 Misfire Detected - Intermittent
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-10 - - - Intermittent
Readiness: 0010 1000
As i said any help would be great!
Address 01: Engine
Coding: 10500
Shop #: WSC 79413
9 Faults Found:
