Carista App
ozzrahog
151
66
Just got my dongle yesterday, looks like the face lift Leon is no longer on beta testing
ozzrahog
151
66
No, it just no longer listed as a car that is eligible for beta testing
ozzrahog
151
66
Fancy have my rear lights on with the DRLs. I know it can be done on OBD11 but can't find it on carista. Am I just missing it or is it not there even on the beta?
Cupra Belfast
307
39
Cheers all, on the beta now
Have you decided what you want to fiddle with yet?
I'm not sure to be honest. I've been making changes to thinks affecting handling & performance, mainly for better off the line and better, ergo safer (in my mind anyway), handling. If it's not on there you can always try emailing them with the coding if you can find it elsewhere? I'll check my app tomorrow to confirm if it's there on mine or not.
Cupra Belfast
307
39
It might be model spec/model specific if you can change it or not? I think the option is there anyway for things you can't change on your vehicle, in that it simply will not take if you try to alter a function beyond the module's capabilities.
Pew.
1,451
142
Scotland
changed the throttle back to time based, i just prefer it now that im stage 1, works better i feel than linear.
ciaranmcw
30
Does the Carista work with any other obd2 apps for Android?
I cannot get any app to connect to it when its connected.
Diga
You can use Torque. It's compatible 100%.
Sent from my G8141 using Tapatalk
cuprawill290
51
13
Northumberland
Just ordered mine, my old OBD2 adapter has dry joints inside its lasted me getting on ten years so can't complain. Other than one click folding mirrors i think i have everything else i need already done on my car, needle sweep et cetera as is the norm on a cupra. any other changes i should look at? as i'm not planning on subscribing just using the free month that comes with the dongle then back to Torque.
Cupra290
STM400
Mar 8, 2016
110
11
56
United Kingdom
Thanks I have all of those options selected as well as the option ticked in the infotainment, I have just applied for the beta so will give that a go one it goes through. It certainly have the 2 sensor holes up by the map lights but cant determine if there is anything behind them. I assume not and its just a case of 1 facia / trim panel for all models. I cant believe that the alarm is an extra on a car of this price range, or that it wasn't ticked as the car was to be a demo model. But I did have to spec the alarm as an extra on my vRS.
Hi.
Hi. If you have the senors then you have the alarm. Try this, get in the car, lock it, sit still for 1 minute then move around, should activate the alarm. A friend of mine does not have the sensors, I payed extra to have it fitted.
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
Hi.
I should probably do this just so I know what the alarm sounds like... I’d be sitting on my sofa moaning about an alarm going off outside as someone smashed my window and pinched my dashcam
