Its just unnecessarily loud and the sound isnt really a very nice one. The car is much quieter without it.Pardon my ignorance chaps as I’ve yet to take delivery, but why are most of you disabling the sound aktor?
Does it wear thin after a while?
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Yes I have the digital dash, thanks for the confirmation.If you have the digital dash I am fairly sure you cant turn on needle sweep as its not supported from memory.
The rear parking display is under the instruments section for me on my 2016 FR. I've not seen pace car light on the app on my old 2013 SE for my 2016 FR, I don't think carista supports it yet. The numberplate bulb check should be under lights or the other sectionHi
Just got my Carista today and had a quick play with the menus.
I've enabled a few options - needle sweep, 1 click mirror fold, seatbelt warning deact, etc but can't see a lot of options which i've seen on youtube vids - pacecar lights, rear parking display, number plate bulb check, etc, etc?
Did a lot of these options change from the pre facelift to facelift cars (mine is a facelift) or is there an updated Carista ap?
Have you tried the beta version of the app? It could be that it's not on the stable branch but I don't see why it wouldn't be.Nope not there on mine? i have the latest version ap so either the facelifts don't support this or it's been deleted from the options
I was watching Razza on youtube going through his options which is where i saw these, trying mine last night i thought it odd i only have half the options he has?
What's the difference with the Beta? i'm not into tech but gather my cheap phone is Andriod - will this work?
The beta version of the app has some extra options you can change on it. If you send an email to carista support asking to be added to the beta program they'll email you back with an invite to join it, then it's just a matter of updating the app in the Play StoreWhat's the difference with the Beta? i'm not into tech but gather my cheap phone is Andriod - will this work?
Apply for beta again same process as before mate they should put you on again!My 1month Beta trial has just expired.
Is there anyway to get this extended ?
Anyone had any luck with a couple settings;
Automatic rear wiper when in reverse gear disabled - still wipes for me in reverse - this REALLY annoys me! Anyone had any luck disabling successfully?
Enable configuration of lock/ unlock beep in menu - doesn’t show in settings or any other menus - tried infotainment reboot still doesn’t show. Not that I use it anyway but it’s there to fiddle with if you want to!
Iv done it on mine and noticed less understeer on a roundabout I normally understeer on.Anyone change the Haldex AWD system setup?
Default is standard and there's "increased traction (more power to rear wheels)
Also, anyone know if the park pilot will activate on a cupra st 2019 reg?
Nice to lower the sound actuator, worth it for that alone
