Don't get this car opened bonnet after work level on minimum open cap level goes to crease on bottle
Lost water yesterday. My head gasket is on its way out checked the water housing and its burnt oh dear
is it deffo the head gesket?any sign of oil in the coolant tank?you can see a floating bit of oil in the light if you look carefully.
was the engine all good before you changed the stat?head the engines are pretty bomb proof before i looked into getting the cupra never heard of the head going?if you go to halfords they got a tester to see if your geaket is/or going.:(
I read some where that if your water pump was on the way out the pipe at the top of the coolant tank would not be flowing out water.(de gasing pipe i think its called on the R5 it had the same thing)
I have had a new water pump 2 weeks ago. It was doing the same before I changed the stat it's only just on its way the coolant is pressurising too and the top hose to the expansion tank is running into bottle fine and gets more when I rev
No not got a clue the garage sed it couldn't be anything else. The coolant system is pressurising and loosing water and the temp gauge starts to go up to near 110 then drops after 2 mins the temp has only gone up twice though
