Changing ECU procedure (Cupra)
BMcN
Mr. Car Carer
Ok, your probably thinking here we go again. But I am not looking for the the VAGCOM part of changing an ECU is very well documented - however I am not able to find anything on actually changing the ECU. I am pretty confident but it doesn't do any harm to double check, especially when playing with with something so valuable.
So is it simply:
Disconnect negative terminal of battery,
Disconnect positive terminal of battery,
Pull ECU out,
New one in,
Reconnect battery,
Ignotion on and VAGCOM it.
Job done? Maybe take a few waterproofing measures while I am in there.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
the ecu's are vented so dont seal em completely over anything that looks liek it should be open
just ask the ex superchips guy who's new *chip* went pop in water enclosed in a tesco bag :p
in the middle of that list
remove wipers
remove scuttle panel
unbolt ecu (3 bolts i think it is on mk2)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
well i did twice :redface: well i tried to - sorry gets confusing written on one line at a time
and when you mentioned t/bodies i was off into 16v mode :redface:
only added it to make sure i could say it in english :whistle:
BMcN
Mr. Car Carer
What are you talking about? You never get more than 2 lines before mentioning your hotrod again :bleh:
Thanks anyway. I'll not make it water and air tight but will try and sheild it a bit.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
theres a plastic shield over it anyway - just make sure its flat and secure
