Changing the gearbox oil on a 2014 6-speed manual 2.0 diesel FR
SuperV8
1,908
971
All I'm saying is that I've done a few thousand miles with the Sintofluid 75W and my gearbox hasn't exploded yet. Fuchs is one of the biggest car lubricant manufacturers in the world, if they say something is compatible with my car, I'm quite happy to take their word for it 🤷🏻‍♂️.
Not saying you shouldn't trust their recommendation - just that their recommendation is NOT the same as an actual approval.
SuperV8
1,908
971
Yes I totally agree, it is their recommendation. It seems to be the common thing now with many brands, not just Fuchs. I guess paying for VAG approvals on that scale would make the oil so expensive no one would buy it. I also wonder if it has something to do with VW TL 525 27 itself, as far as I can tell is a part number as well as a spec, add A2 onto the end of it and you get a sepcific size bottle of it. I think. So can an oil be officially approved for VW TL 525 27? To be honest, I do not know off the top of my head.
Cheers,
Guy
Yes, agree - could be down to either the cost of the approval/testing/licence agreement - or maybe VAG just don't want to licence any other trans oil than their own, but they don't even schedule a gearbox drain/refill period (filled for life - haha if life means 100k) on these so who knows.
I believe G 052 527 is the part number which includes a letter and number on the end to denote container volume, and the TL 525 27 is the VAG specification.
Reactions: oilman
SuperV8
1,908
971
Replaced my gearbox oil at the weekend, car (2014 184TDI) has done just over 90k miles.
Really easy job, went for a drive before to get the oil warm.
Definite improvement in gear change quality/smoothness.
SuperV8
1,908
971
My 184 2014 is on 107,000 miles. You really noticed a difference? I might have to consider doing it.
Hot knife through butter comes to mind!
Yes, definite improvement. I wouldn't call it 'bad' previously, but it would annoy me (maybe not my other half) I could tell it was more resistant to change especially when cold and in the lower gears. Changing gear is more of a pleasure now.
BillyCool
754
323
Leicestershire, UK
Nice one.
Well based on that - I'd better sort it out! I'm doing an oil/filter change soon so can do it at the same time.
Can you just confirm which oil and how much to use. Thanks.
SuperV8
1,908
971
Nice one.
You can see the oil I used in my photo: Castrol Syntrans V FE 75w80.
You can see in the the previous posts for the Fuchs oil alternative and Seat OE numbers.
2.3L required - so 3x 1L bottles.
I found I could just pour the oil in using the small tube with the bottle so didn't need any funnel or tubing.
Reactions: BillyCool
mjgreen81
15
Hi,
Thanks for writing up this guide. I have felt that changing gear in my 2016 1.4 FR has been a little stiff in the low gears this winter so I think I want to change the oil. It's on 80k now so feels like a good time.
Can you confirm if the procedure and oil spec is the same for the petrol?
Thank you
SuperV8
1,908
971
Hi,
Thank you
Have a look in the workshop manuals:
mjgreen81
15
Hi,
Following on from my previous comment, I attempted this today but found that my drain/fill plugs were different than were shown in the guide so I couldn't progress.
The links to the workshop guides don't seem to be working anymore, do you still have the guides please?
SuperV8
1,908
971
Hi,
This thread is about the TDI 6 speed box MQ350.
Your 1.4tsi MQ250 is a different box!
SuperV8
1,908
971
Is there a guide anywhere for my box? I'm struggling to find one. Thank you
Have a look here:
mjgreen81
15
Have a look here:
Thank you very much. This is extremely useful. There is a lot more steps than I was expecting so need to think whether I'm brave enough to attempt this without screwing something up.
Are you able to tell me how I can check that I definitely have the MQ250 gearbox?
SuperV8
1,908
971
What engine do you have?
looks like:
150 1.4 has an MQ250.
125 1.4 has an MQ200.
mjgreen81
15
looks like:
It's 150hp.
A vin decoder says the transmission is RSW(6S) but I am not sure what that refers too.
Thanks for your help. I will do some more research on the procedure to see if I am brave enough to attempt it. Messing with that gear lock lever and removing the reverse switch sounds daunting.
