Originally posted by Mosser
i will start with a 1.5mm hole as my turbo isnt capable of creating more than 24psi anyway (I've tested it with N75 bypassed!!)
Do you already know where could you source a new turbo from?
the restriction in my N75 is 1.65MM, do i need to add a restrictor to this same side of the N75?, or should it be in the inlet to the valve?
Originally posted by neg
I will see what happens ... back in a mo!
What sort of difference should it make ?? Would a smaller hole be worth trying.
