Clicking nosie when Turning
mark.pt
Hi Guys
Had my Leon 1.8T a few weeks now and noticed a clicking noise.
It comes from the front left wheel area and is only noticeable when turning on/off lock when I increase throttle at low speeds. The noise is also speed related (quicker the faster I go)
Have been into a large car parks and driven at constant speed when turning on / off steering lock and the problem isn't there.
Any tips ?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Have you checked to see if you have anything stuck to your brake disc?
What about something fowling the wheel like the brake pad wear indicator wire?
How about the stone guard behind the disc, mine usually gets a bit bent when changing discs and in that area.
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
My bet its the cv joint. Mine is clicking and needs changing. There is a thread on here about it me thinks.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
But usually a CV joint will make a noise when on full lock and driven slowly forward or in reverse.
The above's car doesn't do this
mark.pt
Sorry for no reply's. Just back from a 2 week holiday.
Will take car to local garage on weekend and see if they can diagnose.
Will submit their opinion when checked.
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
mine did this, as you mentioned it was the left... check that your brake pad sensor and ABS sensor cables are not contacting anywhere... mine wore through
gorillaleon
did it solve the clicking i have noticed mine doin this today??
Luke_buk
60
South Yorkshire
it was the outer cv joint that i got done.
just need to keep checking the boots to make sure they are not ripped and leaking grease.
if anybody needs any more info let me know
