Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
No mate , same.......... My mate worked for clifford, and liased with clifford tech U.K / U.S.A, it can be done he looked @ my lcr very simular to golf's etc, The problem is if you want to keep the v.a.g alarm, some of the wiring is via the can-bus, and some wires do two things or more, can confuse the ecu, i.e brake light's on black jax flashing when the brake peddle switch is open circuit, But if the installer is good enough, it CAN be done, with extra relays/diodes and loads more, thing is installers dont want the hassle(or aint good with clifford's), people who are not bothered about the v.a.g alarm which is cr@p will have no hassle, the hassle comes when you want to run both togetherandycupra said:is the LCR alarm very different to say a LC alarm?
flashbsd said:i've got my clifford concept 600 with remote start option, window rollup etc, tilt, and blackjax sitting in the loft in a pile, welcome to anybody with technical guts!![]()
Sulli said:I have had some serious high performance cars, all with BlackJax. There's a reason for that. No Cat 1 stops a thief with keys nicking your car - BlackJax does.
All this insurance talk is a bit over the top - I could never see a scenario where BlackJax would put you in a worse situation with insurance or lack of car than being without it.
The rev threshold can be adjusted, by clifford wiz net, with lappy to 1000rpm, this would only then cut in @ a junction or lights sayg60jet said:okay picture this cos i´ve done it!
you get in you car with the stereo on at a reasonable volume, and forget to disarm the blackjaxx, or your other half gets, you drive off, black jaxx activates at 1500rpm but cos the stereo is on you still miss the flashing light and the siren beeping 3chirps. 30 seconds later your at 70mph you change into top gear and the revs drop, bang blackjax comes in, cuts the engines kills the powersteering and the assisted brakes!! now what would happen if you needed to stop quickly before you had time to put your code in, cycle the alarm and restart the car then reinut the code.
Thats why blackjaxx is not cat 1, it might save you loosing the car but the risk to others is high
Yes, but by that time i'd be readyPabs said:Anyway, in todays world, if someone nicks your car and doesnt get more than 100yards down the road, they'll probably come back and get you out of bed to go and help em get it moving again, with a gun to your head.
