climate control tricks
ralph
125
N.wales
I was looking in the leon section and they can get various bits of information up by pressing varous buttons on the climate control consul. Is there anything like this that you can do on the ibiza cc consul all I can do is change from deg c to deg F any Ideas.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Yes, I've seen this before - I think you can do various tricks on most VAG group cars with Climatronic, but can't remember much about it or how you do it.
Do a search - it's been discussed somewhere before, try searching on "climatronic" that should point you in the right direction....
SIHCTR
The procedure in the new Ibiza is the following:
Turn on the recirculation.
Then press simultaneously the five central buttons of the climatronic: Auto, Econ and the three arrows. You can scroll through 52 codes using the temp knob. However I have no idea what each code stands for!!
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Not sure this is definitive but I was given this for the Leon...............
1 System malfunction - displayed as a Diagnostic Trouble Code (DTC),
2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
6 Digital value of Outside Air (Ambient) Temperature Sensor
7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
9 Delta value of Temperature Regulator Flap
10 Non-corrected specified value of Temperature Regulator Flap
11 Digital value of Central Flap Motor Potentiometer (G 112)
12 Specified value of Central Flap
13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
14 Specified value of Footwell/Defroster Flap
15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
16 Specified value of Air Flow Flap
17 Vehicle Speed (km/h)
18 Actual Air Blower voltage (Volts)
19 Specified Fresh Air Blower voltage (Volts)
20 A/C Compressor (A/C Clutch) voltage (Volts)
21 Number of low voltage occurrences, non-transient
22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
24 Cyclings of the switches, absolute non-fluctuating
25 Analog/Digital value, Kick-Down Switch
26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
27 Coding value
28 Engine Speed (RPM)
29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
30 Software version
31 Display check (all segments of A/C Control Head display light up)
32 Potentiometer malfunction counter, Temperature Regulator Flap
33 Potentiometer malfunction counter, Central Flap
34 Potentiometer malfunction counter, Footwell/Defroster Flap
35 Potentiometer malfunction counter, Air Flow Map
36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
44 Vehicle operation cycle counter
45 Calculated interior temperature (internal software, in digits)
46 Outside (ambient) temperature, filtered, for regulation (internal software)
47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
48 Outside (ambient) temperature, unfiltered, (in digits)
49 Malfunction counter for speedometer (vehicle speed) signal
50 Standing time (in minutes)
51 Engine Coolant Temperature (ECT) in deg C
52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the “88.8” display. See chart below.
53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the “88.8” display. See chart below.
54 Control characteristics
55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
61 Software version (latest)
muddyboots
Oct 16, 2002
5,739
The Mk4 Ibiza doesn't match up to the Leon list - for a start there are a few less readings (about 50 IIRC).
Anyone know of a list for the Mk4 Ibiza ?
It might be useful to diagnose what causes the erratic fan behaviour in the summer (detailed in another thread).
TopGunZ
I didn't understand whether you wanted the exact "keys" to punch...
Well it's like that
Air recirculation activated
Press TOGETHER: AUTO+air up+air middle+air down+ECON (they are the 5 middle buttons)
then you can see every one of 52 readings (don't know what's what yet) with the temp adjusting rotating button
with love from Greece www.ibiza.gr :happy:
TopGunZ
Ooops I just saw my friend SIHCTR's post, sorry!
But well, Greece yet again it is :D
Stephen O
516
Manchester
Pmag, How did you pay for your Fr front vent's? Ive been told by my local stealer that the standard sloted type are about £5 each but the Fr honeycomb style are £25 each!! Is this correct??
PMAG
The price of FR front vent's is +/- 70€, its a set of 5 vents.
No one kwons the codes to see speed,oil temp and water temp on ibiza's climatronic? :rolleyes:
ibiza owner
IBIZA Mk3 1.0Ltr MPi
MaxBrand said:
Is there a way of doing it on MkIII Ibiza's with climate control? :confused:
I cannot seem to do any tricks on my SEAT MK3 IBIZA LCD Display (like change temperature Display from F to C) and things like that.
I have no air con in the car just the basic recirc button, fan + and - (up to 6 speed) buttons and Hot and Cold Buttons.
Any Ideas how to go into secret mode on my cars display or the diagnostic bit?
Thanks,
Andy.
Funny enough only today after 4 years of owning the car I was fiddling and found I can program 4 sound settings or linear sound on the radio by pressing the Bass or treble button and then immediately pressing one of the preset station buttons. - I have never recalled reading this in the supplied radio's instruction booklet before!
Ant FR
2,861
Kent
they are a different colour plastic to the Cupra bumpers and look pooo pie when fitted along side.
S13
85
Has anyone found out which code to use for digital speed yet?
Mattyh87
Sideways as always!
May 7, 2006
220
Manchester
I bought something of e-bay telling me about it, but i have lost the word file i got sent. There are ways of doing it i think!
stevie.w
182bhp 297lb/ft
May 26, 2006
45
COOKSTOWN N.IRELAND
on a hot day even if you turn the knob to the lowest its still not cold or am i doing somethin wrong, the air con on my last car a golf was freezin but the climatronic on the beeza just doesnt get cool enough
T. Spark
Then Id say this isnt the right thread...
Oh and there is something wrong with your car :p
How old is it? The air con unit might need regassing, when you start the car does the air con unit flash?
