Clutch pedal gone really hard and car won't go into gear.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Does sounds like your clutch has gone or is going. This happened on my last car and it needed a new clutch.
WHen was in last changed? Milage?
dave_6
193
Essex
has the pedal just dropped? is it at the same height as the other pedals? if not can you lift it back up with your foot
just to make sure its nothing like that to start with
Suchley
Essex Boy.
May 2, 2009
101
Essex
guy said at 50 k now at 89?
had some work last month at a clutch place they didnt menion a thing.. Looking in side the car ive fount like a switch hanging around after resarching the part its a cruise switch any links to it?
BHP Addict
Back in a SEAT!!
Jan 31, 2006
886
Birmingham
Mate, pop the bonnet and check nothing is in the way of your shifter first.
My oil breather found it's way in there once and I couldn't get into gear. I chopped the plastic pipe down and re-fitted.
The clutch switch is like a bonet alarm sensor looking thing. Like a thumb trigger.
Undo the plug, screw the thread into top of pedalbox (Clutch) and re-plug it back in. Cant see it being this though.
Take it down to the clutch place and ask them to check it out for you (If you can get there)
Suchley
Essex Boy.
May 2, 2009
101
Essex
Lads cheers for the help..
Worked out it was the Casing? bearinsgs? hydrolic cables stuck ? etc etc £340 later i should be able to get it back.
