Clutch / Pedal
sebasti0n
81
Just noticed over the past few days that when I first start driving the Cupra the clutch pedal seems really light to press down and the bitting point seems to be lower than normal...
After a couple of miles, the clutch pedal seems to return to the normall bitting point and the normall stiffness for the rest of the journey.
Any thoughts ???
Going in for a service and cam belt change on Monday, so might get them to look at it !!!!
CRAIGLCR
THE DADDY!!!!!
Nov 14, 2005
363
STOKE ON TRENT
hi mate!! i had the same problem, and my pedal kept on goin to the floor aswell!!!! mine was the slave cylinder leaking!! this is inside the gaerbox though so it was a gearbox off job and whilst it was off i had a new clutch fitted 2 !!!!:)
Ste
47
As craig said, might be the slave. Also, if you're lucky it will be the master cylinder. No gearbox removal to replace this so much cheaper. Definitely get this done though as it's bound to go when you're miles away from home etc etc
