scarface
615
West Midlands
Whenever i put my foot on the clutch pedal and release it makes a squeek sound. Does this mean its on its way out or needs oiling? if its the latter, where do i oil it?
What sort of squeek is it?
does it sound like air or pressure being released at the pedal or does it sound like the clutch slipping??
it wouldnt be a cable because its hydrualic clutch, wouldnt be the release bearing from what you are describing, sounds to me like just a noisy pedal arm. where the arm is fixed to the pedal box the point it pivots maybe causing the squeek, just have a look with a light and spray some wd40 up there where the clutch pedal would pivot at the top or around the spring.
