code logs
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
the other halfs golf is running rough ans smells of fuel, ive logged 2 codes and done a search, most people say maf but thats not that old, its a 1.8 gti Turbo.
any help?? codes are 16487 and 17545,
cheers
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
have you run it with maf unplugged? brittle things mafs, new ones have been known to be broken
also second code suggests running rich... either lambda fault or boost leak somewhere, id be betting on a boost leak. have you checked all the boost and vac hoses for splits, especially the ones under inlet manny?
any acces to vagcom for logging?
Nev_LCR
May 16, 2007
1,271
Ipswich, Suffolk
one under manny has been replaces, the smell of fuel i thought it might be lambda, do they have 1 or 2 and not sure which one i would have to change,
no not run it with it unplugged,
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
16487 - mass air flow sensor (g70): signal too high
p0103-35-10---intermitent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
james walker
May 24, 2007
5,121
retford notts
2 sensors, one pre cat one post cat... code suggests bank 1 too rich which is the first sensor afaicr..
id unplug the maf nev and see if it runs better first.
could do with some fuelling logs to check lambda, or at least voltage test to see if its working.
is there an eml?
james walker
May 24, 2007
5,121
retford notts
try the maf unplugged first nev, if not then id look for boost/vac leaks, mybe get it pressure tested before looking at lambda (costly).
Vagcom logs are the crucial part here tbh
