Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
If it was adjustable then it was either one of those cheap sets with some type of clamp on the spring or a set of coilovers.
Yes the advantage is the height is adjustable between 30-100mm.
just want it looking a little lower to arch /floor not craxy and scrapping the floor
also want to improve the handling too , have upper and lower S3 braces
also have to take into account its a daily driver & i have alittle nipper !!!
what about the Koni 35mm SSK Sport Lowering Springs & Shocks Suspension Kit this anyy good
I was thinking either the STR Koni's @ £310
or
the SPAX VSX @ £275
Only thin is the Koni's go to 35mm where as the Spax are 30mm. I dont really want to go any lower than 30mm as I've herd stories that going any lower can cause problems in the future, damage to other parts/clearance etc !
I dont know much about the SPAX brand name though !
Please dont recommend anything above the prices above as I cant aford it.
The Weitec Hicon GT Coilover Suspension Kit (£390) took my fancy as well, again I dont know too much about Weitec as a brand.
35mm is on stock leon.. minus 10mm for the cupra and -15mm off that for the r.
so 20mm on the r and 25mm on the cupra.
koni strt dont do kit for cupra R do they damien????
