coilpack issuse?
joe_ibiza
Right read this forum over and over, from what it sounds like, my coilpacks/pack has gone, i've tried everything i could find on the forum, i took each one out and started the car, from left to right the first 2 i did the couldn't would even start the last one the car started with the problem, which means it must be the first two or one of them, then i also tried smelling them but the all smelt the same, i have a 1.2 52 reg ibiza, if anyone could help me out i would be very grateful, thanks in advance
joe
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Easiest way to do it is to have the car running and pull the plug on the coil pack one at a time. When you pull out the one that has gone the engine wont change at all, but pull out a good one and the engine will try to stall.
joe_ibiza
righto mate, i'll give that a try in the morning. thanks for the quick reply
RUM4MO
8,107
1,120
South Scotland
There is a Gendan scan tool for VAG cars that costs under £40 delivered that will point the finger to the faulty coil pack - cylinder one is the one nearest the timing chain cover - cylinder three is the one at the gearbox end. I'd reckon that sometimes these coils will not fail on load and at low revs - ie at tick-over or idle speeds - only when under load and higher revs.
