cold side dv kit
Deleted member 12147
Hows your turbosmart DV running myki? any probs? I'm still thinking of getting a new DV but can decide weather to get the forge split-r or the turbosmart. I was told by a guy from Custom Code who has a Forge split-r on his car that it sounds like theres someone sneezing underneath the bonnet.
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
My turbosmarts working perfect mate had no issues at all with it. The sound on it changes with everything you do to the boost pipes ect. Mine went from sounding really aggressive to really smooth since i bypassed both the N112's and took off the SAI. Much louder than the Split R and 007. Will at p-torque will vouch for how loud it is as i was up gettin the map done on weds
P-torque.co.uk
1,075
Wolverhampton
www.p-torque.co.uk
Yes it was loud! Louder than the Splitter for sure.
2 members have made 203bhp with our stage 1 map so far (tested on other tuners Dyno's not ours) [B)]
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
After giving advice to a couple of you guys il write up what bits i used in here for all to see.
I did mine diferent to the others so heres the parts i used:
2x 60mm 90degree silicone elbows
1x 60mm T-Piece with 25mm DV Port
1x Metre of Super/Mega flex silicone hose
1x Length of 63mm alloy tubing (about 10")
A Copper 90degree Elbow from B&Q (cheaper than alloy ones) only about £1.50
And the right amount of jubilee clips, i used 50-70mm ones
If you want to look back on page 2 of this thread you can see what parts others have used
Bing_17
Good list there m8!
