mmm my avg virus scanner throws a wobbly when installing this exe.
The program uses a aspack.nupx installation package which can be used by malware and viruses to get info from your PC and other stuff. I have installed but not registered just yet.
When starting the prog AVG throws up the alert shield saying there's a infection "Multiple runtime compression aspack.nupx".
Saying it uses the explorer.exe process
It is either fine (and thus it's just how the prog works having been written that way) or it's a virus of some kind.
Probably ok, but thought I'd share.
Having problems with this I don't think it's registering an only naeti I'd does owt zjistit stav an konfigurance jednotky close the program after scanning WTF am I doin wrong how do I know if it registers after I enter the number I click the register button the number goes I click ok then nothing :(
Erm was me not reading the Chech right, got it loaded an registerd only prob not is it wont see any modauls it says the interface is ok when i test it so am confused :( but hey got past the 1st hurdel
yep wayne it works on mine really good for the windows as you can roll the windows down before you even get to the car :D
Good for the hot days[B)][B)][B)]
Some reason earlier I could connect to the conviencence modual with this and Vag com now I carnt on either any ideas y should u reset ecu invade I'm locked out with all the attemps I've had ?
Lets hope this doesn't damage the cable software (actually in the connector that goes in the OBD port)
ANyone else tried it now vag com won't work?
