Anyone unsure
To get the window trick to work goto
http://www.motordiag.cz/info/download
download - Motordiag Komfort Manager Lite.
once downloaded install it keep it same
directory etc
Then open it up and go to the about bit you will get a serial number to register it
copy and paste it
next goto
http://www.motordiag.eu/script/mkm-aktivace
and enter in the code and your email address
once done you will get an email straight back with the code to enter in copy and paste that from the email into the software and click ok
it will display a message and timer will count down click ok and your in!
window trick time
Look on the menu for
Aktivace oken = activate windows> click the button
it will say something in czech > and are you sure?
just say yes
and it will write 3 values and wella its done exit out undo all windows and lock the car keep pressing the key fob and all windows go up
Notes
Open Vagcom first if possible get that working make sure you know the com port address you are connecting to either 1,2,3,4
Then when you open Motordiag Komfort Manager Lite. go to the settings bit and check your on the right com port i changed mine from 1 to 4 click test and it will confirm in english and your good to go
