coolant?
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
going to be upgrading my turbo soon so just want to clear things up!!! where is the best place to drain the coolant from? and where to refil it what is the mix and is there a place where you can bleed all the air blocks from? any help would be mush appreciated!!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
lower radiator pipe which side is that on, take it the header tank is the round tank just above the maf ?and do i fill the whole system up till its halfway up the round tank, then run the engine to get it round the system then fill the header tank accordingly or is it once ive filled it till half way the system is full and there is no bleed nipple?
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Only one lower pipe and its on the right hand side, looking at the car. Fill the header, squeeze the pipes, keep filling then run the car and squeeze the pipe. You'll find yourself then putting another few hundred ml's over the next few runs out.
If you don't mind me asking, I presume someone else is fitting your turbo?? As if you need ask these questions your going to have a whole lotta fund trying to fit a turbo!! Their a pain in the arse at the best of times, not to mention this priming the oil system, getting out pressure and just trying to get the old one off.
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
You've got the oil feed and return on the turbo, fill them with oil it aids the lubrications whilst your building up pressure in the system. The turbo will start turning the moment you turn the key, without been primed it'll be running dry for a few seconds this is enough to cause damage!!
What turbo you fitting a fluid bearing turbo or roller bearing??
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
see these are the little things i need to know, and the atp turbo install instructions do not tell you this i will be fitting a gtrs eliminator, is there any other important things i need to know before the install!!!
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Yeh make sure you have a second car to use and a lot of patience... not to mention a grinder if I remember rightly. Best person to speak to would be Hooch as he's fitted the GT28RS he'll know the little turbo specific mod / pain in the arses you need to do.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
lol second car im bookin a week off work to get this done looked at some vortex sites aswell got some good pointers off there but most of the people said its quite easy to do i have prepared most things cos im having to wait for my turbo delivery!!! for example shaved the bottom left corner off mani, just little things like that
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
seatcoober
i really think you maybe making a bad move doing this yorself. it sounds like you have no idea
id say save up to have it fitted or find a mechanic to help.
straight turbo swap i would say go for it but the eliminator has so many problems with fitment...
good luck
