So.. boost seems too high for a stage1?
Car also fitted with a full Milltek exhaust.
Could this be a reason?
INdeed.
But I specified the exhaust mod to Will and I was thinking.. maybe that's why he made a tougher map..
No update, no sign from Will yet.. :S
hi all i have a lc with a stage 1 remap with the same problem asin the fluctuation up over 3.5 rpm and does it about 3 times through the gears 4,5+6. ive changed n75 valve not that,put new seals and piston in dv, changed pipe on top of dv , cleaned and reset trottle body still doing it could it be the same problem with my map that was mentioned (the EGT MAP) please need some advice thanks ....
