I have a seat Ibiza copa edition which use to have cruise control however it stopped working recently. Any ideas pls
Apologies, from under the wipers stick not the steering wheel, my driving is better than my advice![]()
It’s neither of them but cheers. Must be too do with the amount of electrical mods I’ve done to the car.could be clutch or brake switch
check is brake lights come on when you brake.
clutch switch usually it throws a error code, and can be tested through measuring blocks in VCDS
Cruise control stopped working
Hi, Anyone ever had this problem? All of the sudden it stopped working, I have no idea why. Found this errors the last one seems to coincide with the time the cruise control stopped working --------------------------------------------------------------------------------...www.seatcupra.net
Your cruise control stopped working because of your turbo? I have an overboost condition and guessing my turbo could be on the way out too so wanting to know weather this is the culprit?Yes, if you haven't accidentally turned it to off from under steering wheel then could be turbo as that was my first sign turbo on way out.
