cruise control wont work after change of f\b steering wheel, canbus, steering module
this my scan
VIN: VSSZZZ1PZ7R066896 License Plate:
Mileage: 179510km-111542mi Repair Order:
Chassis Type: 1P (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ7R066896 Mileage: 179510km-111542miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 4352
Revision: --H42--- Serial number: SEZ7Z0F3668597
Coding: 0050072
Shop #: WSC 00191 264 15243
VCID: 7AFDA8F7356CC3EE30-802E
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 01324 210 01865
VCID: 73E385D31206B2A673-8026
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
Shop #: WSC 00000 000 00000
VCID: 69DFE7BB40CA7876C9-803C
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004598134
Coding: 81880F2F00041000431D00000000000000007F075C4000
Shop #: WSC 06441 785 00200
VCID: 6CD19EAF4F386D5EB2-8038
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 141206 022 0601
Coding: 00056208
Shop #: WSC 06441
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R5 AIRBAG VW8 029 2522
Revision: 11029000 Serial number: 003B0PR6E9NW
Coding: 0021045
VCID: 2F6B49A3BEAED646D7-807A
Subsystem 1 - Serial number: 6332MSME1451386F
Subsystem 2 - Serial number: 6342MSME1548485E
Subsystem 3 - Serial number: 6351HTS62ADO8M47
Subsystem 4 - Serial number: 6361HTS62AD03B17
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000734
Shop #: WSC 00000 210 01865
Subsystem 1 - Part No: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: 00000226
Shop #: WSC 00000
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 941 A
Component: KOMBIINSTRUMENT VO3 0522
Coding: 0002401
VCID: 2B535DB38AB6AA66FB-807E
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 160114F1001905
Coding: 460203
Shop #: WSC 12345 123 12345
VCID: 7BF3ADF3FA56FAE62B-802E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0522
Shop #: WSC 06402 145 00197
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000518969028
Coding: 0000688
VCID: 3B736DF37AD63AE66B-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.142 H07 1806
VCID: 35677BCB5CF2EC969D-8060
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F0006050D60085F86107C00
VCID: 0303D51342A6822663-8056
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 01324
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000048969023
Coding: 0000688
VCID: 3C716EEF7FD83DDE62-8068
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P2 035 186 A
Component: Radio BVX 0006
Coding: 0042414
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11005001 Serial number: 00000000890291
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11005001 Serial number: 00000000887019
Coding: 0000144
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2PQ5x H23 0060
Revision: 00000001 Serial number: 00000000544948
Coding: 0000422
VCID: 326D40D7AD9CFBAEB8-8066
No fault code found
this my scan
Coding: 0050072
Readiness: N/A
Revision: 00H11001
Coding: 0023170
1 Fault Found:
Coding: 00056208
Shop #: WSC 06441
Coding: 0021045
Coding: 0000734
Coding: 00000226
Shop #: WSC 00000
1 Fault Found:
014 - Defective
Coding: 0002401
Coding: 460203
Coding: 0000688
1 Fault Found:
000 - -
Coding: 00000000
Shop #: WSC 01324
Coding: 0000688
Coding: 0042414
Coding: 0000144
Coding: 0000144
Coding: 0000422
No fault code found
