simonghutton
Need advice as I'm thinking of getting a remap to up the bhp to 225 from 180.
Angel Tuning quoted me £300 ish. Anyone used them before? They didn't mention any other needs i.e the need of some sort of valve (sorry...I forgot the name of it). I have previously got a quote from a company and they said I would also need said valve...upping the price to £400.:think::think:
Also...can anyone recommend a wheel refurb company around the leeds area? Mine are not curbed, but some of the paint has flaked off over time and use of Wonder Wheels.:cry::cry:
Ta very muchly!
Unlikely that you would get 225 out of a 1.8t 180bhp engine or atleast I've not see it with merely software without further engine alterations/upgrades. If you look at this sites ECU sponsors revo,CustomCode etc they mostly claim 200-215bhp. Have a search, plenty of threads about how pleased customers are about recent remaps.
The Forge 007(£80ish) is typically fitted to Cupras and Cupra Rs as its able to handle the pressure from the turbo that the remap will increase.Its easy to fit but that £100 extra seems resanable for map and install. Incidently the stock Bosch dump valve is prone to failure even without a remap, so its worth doing for relaibilitly.
225-235 is basically stage 2 on a 180 LC
You will need a decent DV, decent open cone or panel filter in a box with a good air feed and an uprated TIP
FMIC is reccomended although you can do without it.
If your going Revo or simular you'll also need a 4bar FPR
my stage one LC with a decent air feed, forge dv and cat back exhaust hit 215bhp on the rollers last month.
To be honest though the numbers are irrelevant. A simple remap alone makes the car far more powerful on the road and will make you grin like a lunatic, for a while.
The upgrade bug will then bite you on the arse and empty your bank account as quick as your fuel tank.
Thanks for the replies ;)
Still undecided what to do:confused:
Should I use Angel and not fit any other part and see what happens, or should I upgrade lots of things and prepare myself for bills bigger than Robbie Williams's ego? :think:
