Jul 21, 2022
Hello everyone
Im thinking of buying leon cupra 2017 with 92k km. Car is totaly stock and has known history. And i want to know whats your experience with owning a car after 100k km. Any mayor problems or is it fine?
Thanks for all the anwsers.
My Leon Cupra 280 2015 has done about 153,690km (95,500 miles). It has full Seat service history. The reliability is not bad at all to be honest with it being a VAG car. I had to have the timing chain replaced earlier this year, a shock absorber, radiator, and a suspension level sensor and brackets. Total came to: £1,692. Warranty company paid for the radiator. The rest was out of my pocket. These kinds of costs may be expected with higher mileage cars. Parts are more expensive on Cupras too by the way. Best to find one that’s been looked after like mine, with full service history, as much history as possible, and less owners if possible.
What was the mileage when you bought it?
This was all the repairs that had to be done in your ownership or this year?
Is timing chain common for that kind of mileage?
I bought it at about 90,000 miles in January 2022. The timing chain, radiator and shock absorber were done in March 2022, and the sensor and brackets were done in June 2022. I would say the chain is common, and it’s best to spot early otherwise it can completely ruin the entire engine. Timing chains are supposed to be for life, but different manufacturers define ‘life’ as different things. In most cases, it’s 80-120k miles. I’d factor these kinds of repairs in when looking around. Ask if the repairs have already been done. If not, they’ll most likely need doing. Get a trusted mechanic to give the car a once-over before you seal the deal.
Thats quite alot of repairs for 6 months of owning the car.
Also do u know what had to be done before 90k miles or like 60k and above?
I did call the Seat dealership which looked after the car before me. They said the coil leads and 4 coil boot covers done on 4th Oct 2021 and thermostat housing and water pump replaced as cooling system leaking on same date, the radiator needed replacing due to corrosion (which I had done in March 2022), they noted a dash error; Error P - wiring loom issue, the nearside rear shock absorber was leaking (which I had repaired in March 2022). The guy who owned it before me, his warranty had expired, so he didn’t get those few jobs done before selling on to a dealer. Clean MOT though. Passed every time, no advisories. Bar once due to tyres, but that’s minor.
Okay so not so bad before such mileage, thank you for all the info.
All this is very interesting, but this Forum is for CUPRA cars Not SEAT cars, which is what a Leon Cupra 280 is. So all these posts to do with SEAT cars should be in the "SEAT cars general discussion" Forum, just saying.
It’s okay. It’s not the end of the world.
Reactions: TheSwede
