Yosh
Hi there, can anyone help me with the pin number and wire colour of Clutch Position Sensor and Accelerator Position Sensor...
I have tried, unsuccessfully, to remove the connectors for the above as the space is extremely limited...
CPS looks like two wires: blue/red and blue/???
Any help with this will be much appreciated!
MK4 1.8T Ibiza Cupra ECU# 06A 906 012F
I 'THINK' (wait for someone that knows definatley), that they both go into the central electrics ECU which is just above the clutch pedal. You can get to this ECU by removing the pannel above the drivers feet and then you can get to all the connectors easily. You can see the wires and remove individual connectors. Might be worth a look to see if you can spot the right wires.
Thx mate. On the right hand drive cars, the central electrics is above the accelerator pedal and as such it is near impossible to take the connector off the APS...I removed most of the trim above/ around the pedals but the huge collection of wiring and electrics makes it darn difficult to get to the APS...The CPS has the footwarmer vents blocking access to that connector...Anyone with any idea on how to remove these connectors, PLS HELP :) This is killing me...I need to finish the installation of my WOT Box...
