when mine failed when 1st done.. cyl #3, fuel pump lost pressure on injectors which were "just" delivering enough...
Well the turbo has survived, but I'm still going to break the car, got all sorts;
Stage 3 IHI Parts
- Audi S3/TT 3” MAF Tube + Re-Scaled MAF £70.00
- Samco Mk4 Golf TIP w/ IHI Modified Lower Section £100.00
- IHI Boost Pipe £50.00
- Bosch 440cc Injectors £125.00
- Audi S3 Fuel Pump £125.00
- Jabba Sport Exhaust Manifold & Down Pipe £750.00
- Coolant Feed Pipe £40.00
- Coolant Return Pipe £25.00
- Oil Feed Pipe £30.00
- 3 Bar MAP Sensor £20.00
- IHI VF34 + P20 Exhaust Housing £600.00
IHI Extras / General Requirements
- Jabba Boost Controller £75.00
- Blueflame De-Cat Section & Flexi for IHI £100.00
- Blueflame Cat-Back Exhaust £150.00
- Jabba Sport 3” Heat Shield £145.00
- Forge DV007 Dump Valve £50.00
- Pro Alloy 50mm Intercooler £550.00
- Aquamist Water Methanol Injection + Washer Bottle £250.00
- Evo-Shield Intake Gasket + Longer Bolts £30.00
Extras
- H&R Gas Damping Coilovers £450.00
- Re-Built Gearbox w/ Peloquin Diff £600.00
- Vibra-Technics Competition Engine Mounts £230.00
- SPEC Stage 3 Clutch + Billet Steel Flywheel £350.00
- Wishbones w/ Powerflex Bushes and Vibra-Technics Rear Bushes £100.00
- H&R Front Roll Bar w/ New Bushes & Eyelets £95.00
- Boost Gauge + A-Pillar £65.00
- Front Engine Bed w/ Powerflex Bushes £50.00
- Powerflex Steering Rack Bush £5.00
- Standard ECU w/ Jabba Re-Map £300.00
- Brembo Brakes w/ DS2500 Pads £450.00
- Oil Pressure & Oil Temp Gauge, Holder & Fittings £85.00
- SEAT Sport OZ Wheels & Toyo Proxie Tyres £450.00
If anyones interested you can e-mail me on [email protected] or phone or text me on 07737 384557.
Cupra may live again after all, just not IHI'd... after spending sometime working on the car over the last few days I've decided to fix it as a standard K03 car with possibly a map on it.
It's too clean of a car to break for bits, I'll get it back onto the road cleaner than ever before then sell it when the time is right.
Excellent news mate.
If your repairing the engine though, is it not worth keeping the IHI setup on it, just uprate the valves?
Matt - Still fancying a change, I've made a decent amount back selling off modifications and just fancy a standard mapped K03 car to run around in for a few more weeks before changing.
Need to find the following parts;
- Full Standard Exhaust System inc. DP & CAT
- Standard Gearbox
- Wheels & Tyres
- Airbox
- Washer Bottle
- AUX Belt
And thats about it, sourced a block and some front brakes :D
- Standard Gearbox
- Wheels & Tyres
- Airbox
- Washer Bottle
- AUX Belt
Do you need the spare pistons, rods and valves i have?
Dont suppose you have the fuel pump out do ya? just curious to how jabba blank of the other feed on it.
You sorted for standard manifold and turbo as i have them too.
Fuel pump will be coming out tomorrow, I'm interested to see what Jabba have done as it looks like they've used half the Mk3 stuff and half S3 stuff!?!
Sorted for standard turbo's and bits will just need gaskets and studs.
- Standard Gearbox
- Wheels & Tyres
- Airbox
- Washer Bottle
- AUX Belt
Craig - I would be willing to do a deal for my standard cupra wheels + cash for your SEAT Sport OZ Wheels & Toyo Proxie Tyres...
Interested? I've sent you quite a few messages mate, why is there no love? :shrug:
Standard interior's all back in and done, now just need to fit the brakes than should be here Sunday then crack on sorting the engine and gearbox out. Once back together it'll get a map and be driven for a few weeks whilst been advertised for sale...
Can't sell it without giving it an extended test drive to make sure everythings right, or thats what I keep telling myself, I know when its all up and running I'll want IHI again lol!!
You do realise that driving an remapped ko3 after IHI is going to feel like your riding a bike...backwards!
Glad maybe some kind of good can come from jabbas dare I say it mistake. Replied to your thread in the wanted section as I have a dp and cat.
Yep but I'm driving a 1.4 Golf (my runaround) all the time at the moment so it's better than nothing. Problem is all the potential next car's I fancy have all felt slow as sh*t I just have to blank the speed factor and look at the handling and potential to go fast.
Still I've got my K4 GSXR600 to play on for when I'm bored at the mo!
