MrJackHarding
Fairly new to the forum (and before anyone asked I've used the search bar).
Have just ordered a coilover kit along with topmounts/bearings. I will also be ordering 15mm spacers for the front and 25mm for the rear. Looking at going fairly low.
Do I need adjustable droplinks for the front? Or do these not work due to the differen't droplink design (on the strut). I'm reading a real mix of stories on different forums.
If not, I'm assuming an upgraded front ARB is the only option.
Thanks in advance for any input!
cupra r will go as low as u like on the standard setup
a cupra has different roll bar which fouls the drive shaft when u go too low
Thanks, thats perfect. Saves me spending silly money on a new ARB. Looking at dropping 70mm ish.
More money for other bits :)
