cupra r fog light
danfr
49
horsham
Having a problem with my cupra r style front fog lights...
one of them works fine. the other one only comes on if you bash the glass.
so i decided to swap the bulb for a new one and it blew instantly (55W halogen H3). thought that was odd so i checked the fuses and a 15W fuse had been fitted in place of the 5W that should have been there. so i put in a 5W fuse + tried the lights - the fuse blew
any input, ideas or suggestions would be welcomed.
cheers
danfr
49
horsham
...the actual fog light bulb housing.
thats why i thought the bulb was at fault but then the new bulb instantly melted
danfr
49
horsham
damn. i just checked the bulbs i tried and they were only rated 6V. shouldve been 12V - no wonder they melted.
still not sure why the fog only comes on when i tap it? gonna try cleaning the contact points and pop a new fuse in tonight. thanks for your response Rick.
i guess the handbook is wrong and a 15A fuse IS correct for the the fog lights
car_guy143
183
Leyland, Lancs, UK
I had the same problem with one of my numberplate bulbs, it'd only come on after a tap. I just took the bulb out and gave the contacts a clean with some WD40 and it did the trick.
danfr
49
horsham
thanks for the ideas.
i cleaned the contacts on the bulb and the housing with some fine sandpaper and wd40 and the problem was still there. So i gave the actual plug contacts where it connects to the loom a good clean and hey presto! mustve been getting a bad contact. cheers
